Date/Time: Sat, 25 Jan 2025 01:06:52 +0000
Scrolling with Crosshair enabled
View Count: 1164
[2019-01-11 09:59:36]
User722856 - Posts: 78
Dear Sierra,
I have a question regarding scrolling the X-axis (Time) without Zooming in or out.
I want to achieve that the Crosshair is enabled by default – but i want to be able to drag the chart left/right(time), as if i would be in Pointer or Hand mode.
Draging up/down(price - y-axis) is possible with crosshair enabled, if i click ALT on the keyboard and then DRAG the chart.
Is something like this possible also for the x-axis?
I found some pictures in the board (see below) a scrollbar on the x-axis.
This would be also a feasible solution, but i cannot find the setting for enable this scrollbar.
Thanks in advance.
Best regards
Date Time Of Last Edit: 2019-01-12 08:58:43
imagescrollbar.jpg / V - Attached On 2019-01-11 09:58:35 UTC - Size: 34.17 KB - 309 views
[2019-01-19 09:53:42]
Any hint in the right direction would be appreciated.
[2019-02-11 09:05:17]
After weeks of searching i found at least the scrollbar myself, it was pretty obvious, but sometimes you dont see things...
Menu --> Chart --> "Show Scrollbar"
[2019-02-11 18:48:32]
Okay we thought you were asking about some other kind of alternative scrolling. Of course you can use the scrollbar. It is there by default. Either you disabled it or you had been given a Chartbook from someone that did not have the scrollbar enabled.
