Date/Time: Fri, 24 Jan 2025 07:20:02 +0000
chartbook lighting is not working right
View Count: 625
[2019-01-10 17:45:10]
MMX - Posts: 119
I use a dark blue background for my charts, when I start Sierra, the colors and the brightness are just as they should be. But once I do something on the chart, such as using a tool, the brightness level of the entire chartbook dims significantly and stays that way. But if a menu box is brought up, the brightness of the chartbook returns to normal and stays that way as long as the menu box remains opened. As soon as the pop-up menu box is closed, the chartbook goes back to being dimmed again. Is there anything I can do to correct this? Thanks.
[2019-01-10 19:42:35]
That sounds like a system-level issue on your side. We have never heard of anything like this before. And do not observe it either.
