Date/Time: Fri, 24 Jan 2025 07:31:34 +0000
Trade Service Log Window opens in main window when using detached trade chart
View Count: 601
[2019-01-10 16:07:55] |
User796776 - Posts: 95 |
Testing the trade position limit and order quantity limit on a symbol and trading from a detached chart, when an error is triggered the Trade Service Log opens from the main sierra window (which I have minimized) so the icon highlights in the taskbar. Is it possible for the Trade Service Log to be opened in the context of the detached window so it is visible to the user? |
[2019-01-10 19:38:06] |
No, that window is connected with the main Sierra Chart window.
[2019-01-10 19:43:00] |
I am able to open the Trade Service Log manually from the detached window and it opens successfully as a detached window. I just don't normally have it open and wanted it to open automatically.
