Date/Time: Fri, 24 Jan 2025 07:38:47 +0000
Market depth sync
View Count: 558
[2019-01-10 15:12:46] |
User42554 - Posts: 16 |
Hi, is there any possibility how to sync market depth data on terminal against SC server? I use SC as server and terminal, unfortunately terminal is running only when I'm in the office. I can sync it via classic sync tool, but it should be good implement this option into SC as it sync market data when it starts. Martin |
[2019-01-10 19:03:30] |
This eventually will come, but there is no support now for downloading historical market depth data if that is what you are referring to.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-10 19:03:56
