Date/Time: Fri, 24 Jan 2025 07:28:23 +0000
Constant blinking from picture 1 to picture 2, why?
View Count: 865
[2019-01-10 14:53:43]
User452567 - Posts: 38
When I am using bid and ask depth bars study, the study is constantly blinking from picture 1 to picture 2.
How can I see the chart without this blinking?
http://my.jetscreenshot.com/30734/20190110-ttqg-114kb
http://my.jetscreenshot.com/30734/20190110-evdp-140kb
Thank you
[2019-01-10 19:06:50]
It does this since you have the Calculation Mode set to Sum Ask Side. Therefore, as a new bar is started, the Ask depth starts at 0, so the scale is adjusting to show you the 0 value (or near 0 value) and then adjusts itself as the most recent bar increases in value.
You can set a User Defined Scale Range for the study:
Chart Scale and Scale Adjusting
Date Time Of Last Edit: 2019-01-10 19:07:53
