Date/Time: Fri, 24 Jan 2025 07:40:19 +0000
[Programming Help] - VOLUME PROFILE LOCKED not matter what i do
View Count: 674
[2019-01-10 13:02:59]
User216960 - Posts: 6
my volume profiles seem to be locked after i updated to the latest version. all new AND previous VP now are locked and cant be moved or adjusted. Is there a universal setting to lock them? or some other reason this has happened?
thank you in advance for your answers
[2019-01-10 19:09:40]
Are you noticing this on version 1859? And are you referring to moving of manually drawn volume profiles? If so, refer to:
Volume By Price Study: Modifying Manually Drawn Volume Profile
We are not aware of any problem on version 1859. Some earlier versions did have an issue with modifying manually drawn volume profiles but that is resolved.
