Date/Time: Fri, 24 Jan 2025 07:28:40 +0000
[Programming Help] - trading system based on alert condition
View Count: 662
[2019-01-10 06:40:50] |
Bedhog - Posts: 179 |
Hello Team, This is a 2 second chart of NQ. I have a study called SE1 that triggers a short correctly. However, as soon as the oco target is hit, the system makes another entry in the same direction without firing SE1 again. I have confirmed the criteria for the SE1 trigger is false on the 2 bars shown in the image and I added a spreadsheet to have a closer look. The spreadsheet confirms... no valid SE1 trigger on any subsequent bars. |
[2019-01-10 08:39:58] |
This section here explains this kind of behavior and is also applicable to the Trading System Based on Alert Condition study: Spreadsheet Systems, Alerts and Automated Trading: Disappearing Arrows or Signals Also refer to: Automated Trading Management: Troubleshooting Automated Trading System Behavior Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-10 08:40:13
[2019-01-10 14:13:44] |
This was resolved by sorting the Studies To Graph based on ID, and by re-ordering the decisions that make up the trigger signal.
