Date/Time: Sun, 08 Sep 2024 03:50:22 +0000
Heiken Ashi Smoothed
View Count: 1997
[2013-11-10 10:25:50] |
8fold - Posts: 23 |
Do you have documentation for Heiken Ashi - SMOOTHED. I see you have for the simple version, but how it differs to the smoothed one. Thank you! |
[2013-11-11 07:25:15] |
We will work on this.
[2013-11-13 04:03:54] |
Here is the documentation: https://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s314 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-13 06:29:03] |
8fold - Posts: 23 |
Thank you!
