Date/Time: Fri, 24 Jan 2025 07:17:50 +0000
Historical Charts not loading uptodate data
View Count: 694
[2019-01-09 14:48:19] |
sftrosso - Posts: 4 |
I just started using SC and tried loading historical data from SC Data and TD AMeritrade for TPO Value Area analysis. I only get data until Dec 27 2018 and cannot change the range on the graphics setting. How is this adjusted_ Thanks |
[2019-01-09 17:20:54] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-10 12:40:04] |
Software version: 1842 64-bit | 2019-01-10 07:13:28 Usage end date: 2019-01-29 | 2019-01-10 07:13:28 Enabled for: Advanced Features. | 2019-01-10 07:13:28 Enabled for: Advanced Features 2. | 2019-01-10 07:13:28 Enabled for: Sierra Chart Historical Data Service. | 2019-01-10 07:13:28 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-01-10 07:13:28 Current selected Data/Trading service: SC Data - All Services | 2019-01-10 07:13:28 Chart Update Interval: 500 | 2019-01-10 07:13:28 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-01-10 07:13:28 2019-01-10 07:13:28 Local computer time | 2019-01-10 07:13:28 2019-01-10 12:13:28 Local computer time in UTC | 2019-01-10 07:13:28 2019-01-10 07:13:28 Local computer time in SC Time Zone | 2019-01-10 07:13:28 2019-01-07 15:42:49 Server time in UTC | 2019-01-10 07:13:28 Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-01-10 07:13:28 Program path: C:\SierraChart\ | 2019-01-10 07:13:28 Data Files path: C:\SierraChart\Data\ | 2019-01-10 07:13:28 OS Version Number: 6.3 | 2019-01-10 07:13:28 Locale Setting: C | 2019-01-10 07:13:28 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-01-10 07:13:28 Intraday data recording state for symbol NGG19 is set to download 'Pending'. | 2019-01-10 07:38:12 Reloading all charts with filename: NGG19.scid | 2019-01-10 07:38:12 HD Request # 158 | Downloading Intraday chart data for NGG19 to the file NGG19.scid. Service: nymex | 2019-01-10 07:38:12 HD Request # 158 | Download start date-time: 2018-07-08 08:38:12.000 | 2019-01-10 07:38:12 HD Request # 158 | Using server: ds7.sierracharts.com port 10149 | 2019-01-10 07:38:12 Socket (1) | Creating socket. | 2019-01-10 07:38:12 Socket (1) | Connecting to IP: 8.18.161.133. | 2019-01-10 07:38:12 NGg19 1 Min #3 | Reloading chart. | 2019-01-10 07:38:13 NGG19 #4 | Reloading chart. | 2019-01-10 07:38:13 NGg19 1 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NGg19.scid | 2019-01-10 07:38:13 NGG19 #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NGG19.scid | 2019-01-10 07:38:13 HD Request # 158 | Setting DTC encoding to Binary VLS | 2019-01-10 07:38:13 HD Request # 158 | Sending historical data logon request message. | 2019-01-10 07:38:13 HD Request # 158 | Requesting Intraday data. Start date-time: 2018-07-08 08:38:12. Record interval: 0. Symbol: NGG19 | 2019-01-10 07:38:13 HD Request # 158 | Decompressing data. | 2019-01-10 07:38:13 HD Request # 158 | Receiving Intraday data for NGG19 starting at 2018-07-08 19:56:32 | 2019-01-10 07:38:14 HD Request # 158 | Timestamp of first Intraday data file record written: 2018-07-08 19:56:32 | 2019-01-10 07:38:14 Socket (1) | Signaling to core to close socket | 2019-01-10 07:39:25 Historical data download thread signaled to stop. | 2019-01-10 07:39:25 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 07:39:25 HD Request # 158 | Received 1303226 records from 2018-07-08 19:56:32 to 2019-01-10 07:28:10 (185.5 days) and wrote 1303226 records for NGG19 | 2019-01-10 07:39:25 HD Request # 158 | Completion time: 1m 13s | 2019-01-10 07:39:25 HD Request # 158 | Intraday data download complete for NGG19. Unique request ID: 156 | 2019-01-10 07:39:25 Removed historical data download ID 156 | 2019-01-10 07:39:25 Real-time Intraday chart data file updates started for NGg19 | 2019-01-10 07:39:25 Intraday chart data file opened for NGg19 | 2019-01-10 07:39:25 Socket (1) | Socket gracefully closed by remote side. | 2019-01-10 07:39:26 Socket (1) | Closed. | 2019-01-10 07:39:26 |
[2019-01-10 19:32:52] |
There is current data for that symbol being downloaded so there is no problem with that. The other things to check are: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Incorrect Chart and Session Times Settings And make sure you have scrolled the chart to the very end. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
