Date/Time: Fri, 24 Jan 2025 07:36:09 +0000
roll
View Count: 759
[2019-01-09 11:38:14] |
arruga - Posts: 253 |
Hi there Could you explain please what I'm seeing in my data feed with WMH19? http://www.sierrachart.com/image.php?Image=1547033658447.png Seems like it's not back adjusting, although I have set up the volume-based adjustment setting? it's doing it fine with all other symbols ...or something to do with the feed? ...or to do with the recent mess in JPY? thanks a |
[2019-01-10 09:24:03] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After that: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-10 20:12:00] |
When I update from server I will lose all my customized symbol settings, where I've changed the session times, and it'll revert back to server default session times... it'll be a pain to restore my settings ???? |
[2019-01-11 03:08:45] |
Some Session Times would be reset back to the default. This is a problem that we are going to solve as soon as we can but this is a potential issue.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-11 03:08:55
