Date/Time: Fri, 24 Jan 2025 07:39:56 +0000
Forex Data - More Than 2 Years
View Count: 651
[2019-01-09 08:34:11] |
User9415867 - Posts: 38 |
Is there a datafeed that works with SC or is supplied by SC that receives longer than 2 YEARS of historical data for FOREX?
[2019-01-09 08:54:59] |
Not sure why you are asking that question, this is currently supported. Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-10 09:18:55] |
When I try to load 2000+ days FOREX does not go back that far. It usually gives me about 6 monthly bars and thats it.
[2019-01-10 09:27:37] |
Follow through the step-by-step instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
