Date/Time: Fri, 24 Jan 2025 06:38:27 +0000
Trade Service Log Error
View Count: 711
[2019-01-08 20:03:51] |
drchadbaginski - Posts: 3 |
I had this pop up today when I was filled. CQG. Live. No problems before or after. All orders were filled correctly. I’ve used Sierra for charting for about nine months. I only run a single chartbook with one chart. I have never placed an order through Sierra. I use Jigsaw Daytadr to place all orders and manage positions. Sierra is connected with the $10 additional user CQG login. I have been extremely satisfied with my Sierra experience. Should I be concerned about managing my positions? I wanted to let you guys know about the error. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=24980 |
[2019-01-08 21:13:26] |
From our perspective this is not anything we have any control over. It does indicate a malfunction on the CQG side and it is nothing we would follow up on and it does not cause any harm either.
[2019-01-08 21:18:11] |
Thank you!
