Date/Time: Fri, 24 Jan 2025 06:45:11 +0000
Overlay 5min bar to 2000tick Chart
View Count: 649
[2019-01-08 18:53:47] |
User260560 - Posts: 37 |
Hi there, I'm trying to overlay SPY 5min chart to its 2000tick chart, and I couldn't figure out how to get exactly what I want. So i use study/price overlay study, and use the containing match and multi-column rectangle selection, but I can't seem to change the study/price overlay subgraph settings. Every time I change something from the default setting and click apply, it just goes back to the default setting. Right now the rectangle shows the 5min high and low, and I'd like to rectangle section to be the 5min candle open and close, with wicks for high and low. Could you please advise how to achieve that? Thanks!
capture_003_08012019_133918.jpg / V - Attached On 2019-01-08 18:50:56 UTC - Size: 161.41 KB - 309 views capture_002_08012019_133858.jpg / V - Attached On 2019-01-08 18:51:24 UTC - Size: 87.18 KB - 306 views capture_001_08012019_133840.jpg / V - Attached On 2019-01-08 18:51:42 UTC - Size: 86.91 KB - 341 views |
[2019-01-09 12:00:24] |
What you want to do is not supported.
