Date/Time: Fri, 24 Jan 2025 12:53:06 +0000
Alerts log entry just one time exclusively upon bar close?
View Count: 849
[2019-01-08 18:27:41] |
User14953 - Posts: 236 |
Hi, Can SierraChart make an alerts log entry just one time exclusively upon bar close? Window >> Alerts Manager >> Alerts Log |
[2019-01-08 18:47:32] |
How is the alert generated? Are you using the Alerts tab of the Study Settings window?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-08 18:47:37
[2019-01-09 16:25:38] |
Hi, The alert(s) are generated by Spreadsheet Study formulas - reporting from row 3 - that I've entered within columns K through Z. Drawings are posted to chart(s), arrows and what-not, and Alerts are viewed on the Alert Manager Window, Alerts Log Tab. Yes, I'm using the Alerts tab of the Study Settings window. I'm familiar with and spent time with the Chart Studies >> Study Settings >> Alerts Tab and check boxed _Alert Only Once Per Bar, and/ or _Evaluate On Bar Close under several permutations. No joy yet. Thanks |
[2019-01-09 19:15:29] |
You need to use these particular Spreadsheet System/Alert study inputs: Spreadsheet Systems, Alerts and Automated Trading: Signal Only on Bar Close (Signal Only On Bar Close (Columns K, M) | Signal Only On Bar Close (Columns L, N-Z)) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-09 19:15:56
[2019-01-23 08:51:52] |
Spreadsheet Systems, Alerts and Automated Trading: Signal Only on Bar Close (Signal Only On Bar Close (Columns K, M) | Signal Only On Bar Close (Columns L, N-Z)) I don't see "The Strict Signal Only On Bar Close Evaluation Input" Looking at the Study Settings >> Settings and Inputs tab I'm seeing . . . Input name Alert Only Once Per Bar Signal Only on Bar Close (Columns L, N-Z) Signal Only on Bar Close (Columns K, M) SC v 1400 have this feature? |
[2019-01-23 23:18:47] |
No you need to run the current version of Sierra Chart for this.
