Date/Time: Fri, 24 Jan 2025 07:39:43 +0000
[User Discussion] - LMAX OCO orders - does it support server side trailing (set to breakeven)
View Count: 920
[2019-01-08 09:53:45] |
Cavalry3162 - Posts: 523 |
Hello SC, do the Sierra Chart DTC to LMAX server side thing OCO orders trailing - set to break even in particular - as well? i couldnt find it in the docs... thanks, Andreas |
[2019-01-08 10:02:05] |
No.
[2019-01-10 15:58:56] |
i see.. are there plans to integrate that? as an alternative: if i am using sierra on a server, connect it to lmax and let it run 24/7, now connect a 2nd sierra to that sierra instance on the server via dtc and send my orders from the 2nd instance via dtc to the sc instance on the server and then to lmax, what happens when i disconnect the 2nd instance? are those orders held on the server instance of sierra? would it then move the stop to b/e? if not, is there another way how to achieve that? thanks, Andreas |
[2019-01-10 21:05:05] |
i wonder why you guys cant just answer that dtc question... that "User Discussion" ignorance is really pissing me off |
