Date/Time: Fri, 24 Jan 2025 06:41:35 +0000
stop limit / OCO problem
View Count: 560
[2019-01-08 06:42:48] |
nikoniss - Posts: 3 |
hello, i know this is gonna sound really silly and must be something that i set that caused such problem, but no matter whichever attached order / OCO type I chose, after entry the immediate stop and limit is always just a few ticks above and below my entry, despite having input a price manually. In other words, the attached order seems to ignore the price i entered manually. Date Time Of Last Edit: 2019-01-08 06:44:36
[2019-01-08 18:21:40] |
The first thing to do is to make sure you are configuring the Attached Orders on the Targets tab of the correct Trade Window. Refer to: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Also Attached Orders are specified as offsets from the entry price and not as specific prices. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
