Date/Time: Fri, 24 Jan 2025 06:45:11 +0000
ASX Listd Equities Data
View Count: 876
[2019-01-08 01:51:58] |
User580737 - Posts: 8 |
Apologies new user here. Is there anyway I can chart ASX (Australian Stock Exchange) listed equities in Sierra Chart - using CQG data feed or any other data feed if available. Thank you
[2019-01-08 19:24:44] |
This data can be obtained from the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service ASX stock symbols: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=1#ASX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
