Date/Time: Fri, 24 Jan 2025 05:24:55 +0000
[Programming Help] - Ordertypes setup on spreadsheet for trading
View Count: 578
[2019-01-07 19:56:17] |
User871277 - Posts: 34 |
Hi altogether, I am somewhat new to sierra. Overwhelmed by the Order options. Backtesting gave me 100 ticks to even almost 1000 and uncontrolled runaways (and also again 700 ticks minus). I set up my strategie, which is sensitive to trend and changes, using Renko 5t in JPY E-micro / E-mini. I wonder if someone has some idea about how to set up orders. Aim would be to have primary trailing stop Order controlled server side, and a OCO Order for protection, but OCO order should not cancel primary (that would happen by trailing stop). Also I could go with clientside closing signal, but i consider that risky. Any advice how to set up orders "correctly" In other words, main order, trailing stop, stop Level 10 ticks, additional OCO server side order with 5 ticks to protect entry and minimize risk to 5 ticks, all Server side controlled. Is that possible? And yes, if you can transfer me to a consultant / programmer that would be fine, since I manage datanalysis, and figuring out my strategy, but I am bit scared of those overwhelming order options available. Date Time Of Last Edit: 2019-01-07 19:57:03
