Date/Time: Fri, 24 Jan 2025 05:25:06 +0000
how to show independent scaled study value in left "values scale"
View Count: 1006
[2019-01-07 18:23:34] |
User71961 - Posts: 144 |
1) i have added the study "Study Overlay - OHLC" to a price chart 2) then ticked "independant" for the scale on settings and inputs 3) In Chart Settings - Advanced tab, i ticked "use left side scale" so i can see a values scale on both the right and left side of chart (so far, all good) I want the value of the overlay study to show up in the left side values scale...but can't get that to work. How do i make the study value show up inside the left side values scale? In the Overlay OHLC Study settings, Subgraphs tab, for "Last" i ticked Value Label and Reverse Colors...but None of the "Horizontal Align" options listed work...i hoped that Left Edge, or Values Scale would...but they do not. Any ideas? Could you add another option for "Left Side Values Scale" ? |
[2019-01-08 03:24:05] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
