Date/Time: Fri, 24 Jan 2025 05:15:55 +0000
Volume At Price Threshold Alert V2
View Count: 1357
[2019-01-07 17:36:16]
User333787 - Posts: 3
Hello Support,
Would it be possible to allow the Comparison Method of: Ask Volume Bid Volume Diagonal Difference, to enter a Volume Threshold also? I want to see the Percentage Threshold of X% with a minimum volume of Y.
Also an option to allow the extension lines to continue until a future bar close below when a positive (Diagonal Ratio) is entered or a future bar close above when a negative bar close when a negative (Diagonal Ratio) is entered? See attached picture.
imageEZ.JPG / V - Attached On 2019-01-07 17:32:32 UTC - Size: 25.76 KB - 796 views
[2019-01-07 19:33:55]
You need to modify the study to meet your requirements. Refer to:
How to Build an Advanced Custom Study from Source Code
