Date/Time: Fri, 24 Jan 2025 05:10:29 +0000
password lost for second account
View Count: 992
[2019-01-07 16:17:56] |
User70416 - Posts: 19 |
I set up a second account and have lost the password to it. Can you please reset it? The second account is: sslow2002 Please do not reset the password on this account I am posting on. I am unable to respond to your question on the "sslow2002" account because I can not sign in. Also, can you please reset my trial period on sslow2002? I have not been able to even start using it. Thank you Scott Lowrance |
[2019-01-07 16:29:29] |
Sierra Chart - Max - Posts: 5779 |
Refer to the Account Password Reset page here: https://www.sierrachart.com/PasswordReset.php Sierra Chart Support |
[2019-01-07 21:48:14] |
Let us know if you need more help. There is currently an active trial on your sslow2002 account.
