Date/Time: Fri, 24 Jan 2025 05:16:30 +0000
.cht file keeps closing my system
View Count: 1302
[2019-01-07 15:01:14]
KXRCap - Posts: 64
Dear SC -
I cannot figure out why the .cht file keeps abruptly closing SC.
It loads to a point then closes the program. It did load when I built it.
It is attached.
[2019-01-07 15:01:56]
Sierra Chart - Max - Posts: 5779
Please re-attache the chartbook, as for some reason the previous attachment failed.
Refer to the Attaching a File section here:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
Sierra Chart Support
Date Time Of Last Edit: 2019-01-07 15:03:17
[2019-01-07 15:09:30]
KXRCap - Posts: 64
re-submit
attachmentKXR-STOCKS-NQ-ES-RTY.Cht - Attached On 2019-01-07 15:09:03 UTC - Size: 2.02 MB - 374 views
[2019-01-07 19:37:08]
We did test your Chartbook and did not encounter any problems with it. It opened reasonably fast and no exceptions or other problems. No problems at all and it is still running.
This probably is not going to make any difference because we see you are not using custom studies but run Sierra Chart in Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
We are suspecting a system-level issue.
[2019-01-07 19:42:57]
KXRCap - Posts: 64
Hmmm...
I am not running in Safe Mode... does not work for me... but I will do a re-build from scratch and see.
