Date/Time: Fri, 24 Jan 2025 06:52:43 +0000
Kase bars
View Count: 1653
[2019-01-07 13:33:53] |
User635423 - Posts: 51 |
Hello, Does sierra charts have Kase bars? Thanks |
[2019-01-07 19:39:41] |
The safe answer would be no but we think there is a custom study that does these but really we would not recommend it because it is older and not the most efficient implementation.
[2019-01-08 12:42:50] |
User90125 - Posts: 715 |
Kase Bars are simply an early implementation of Range Bars. To match Kase Bars, try using SC's True Range Bar setting, with no gap fill. More info here: https://www.netpicks.com/day-trading-tool-box-kase-bars/
