Date/Time: Fri, 24 Jan 2025 05:16:16 +0000
Im having trouble with Attach Trade Window to Chart
View Count: 686
[2019-01-07 12:47:11] |
1234567 - Posts: 42 |
how do i fix Attach Trade Window to Chart, not the spreadsheet. because the spreadsheet it right, but not the Attach Trade Window to Chart. the Attach Trade Window to Chart is not triggering where the spreadsheet is triggering. the spreadsheet is triggering in the right place. how do i fix this Attach Trade Window to Chart? and yes both are synchronize to sim13, the Attach Trade Window to Chart and spreadsheet. |
[2019-01-07 19:26:47] |
We do not think we are understanding what the particular issue or question is. Can you be more clear and precise about what you are asking about. We do not think this is about attaching the Trade window to the chart. You can easily do that through the Trade menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-07 19:34:50
