Date/Time: Fri, 24 Jan 2025 05:18:38 +0000
Chart Drawings Question
View Count: 690
[2019-01-07 01:42:02]
Rainer - Posts: 110
fyi. in version 1856 one can not select (highlight) chart drawings. ie. can only click and move a Parallel Line (at the same time), but can not "select" Parallel Line by simply clicking it.
Subsequently I rolled back install to 1852, and it is working correctly again.
imageCapture1136.JPG / V - Attached On 2019-01-07 01:39:10 UTC - Size: 70.36 KB - 316 views
imageCapture1137.JPG / V - Attached On 2019-01-07 01:39:33 UTC - Size: 79.12 KB - 269 views
[2019-01-07 22:07:25]
There definitively is not a problem with this. Make sure this option is disabled:
Chart Drawing Tools: Support Drag For Chart Drawing Creation/Modification (Global Settings >> Tool Settings >> General >> Tool Options)
If you do have that option enabled, the behavior is correct if this option is disabled:
Chart Drawing Tools: Keep Chart Drawing Selected After Modification (Global Settings >> Tool Settings >> General >> Tool Options)
