Date/Time: Fri, 24 Jan 2025 05:08:35 +0000
referring to price data in a study not based on price
View Count: 602
[2019-01-06 10:57:46]
User470516 - Posts: 78
Dear SC Team,
I am writing a piece of code that is "based on cumulative Delta Volume" as defined in the study setting window. When I refer to sc.Low, this naturally refers to the low of the cumulative Delta Bars. How can I actually access to the price lows and not cumulative Delta lows in such a study?
Thank you for your support.
Best regards,
Laurent
[2019-01-07 08:11:35]
Dearm SC Team,
I my previous post re: this, I was looking for an elegant and quick way to access prices data (low, high, close,...). I know I can put these in subgraphs of the price region and then do sc.GetStudyArrayFromChartUsingID in the region where I need them.
Thanks.
Laurent
[2019-01-07 08:12:33]
Refer to:
ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function
