Date/Time: Sat, 27 Apr 2024 03:32:39 +0000
[User Discussion] - Imported CSV Data cannot be group into Quarterly or Yearly Data
View Count: 693
[2019-01-06 06:28:25] |
User164231 - Posts: 278 |
Hi, I have imported monthly SP500 data from yahoo finance to SC chart, how do I convert the data to quarterly or yearly candle? When I chose Historical chart it says the symbol is not found. What is the work around? thanks. |
[2019-01-08 03:38:12] |
You just select the time period as you would for any other chart, keeping in mind that if you select a timeframe that is smaller than what was in the file the data will not show correctly. Refer to: Changing Chart Bars Period Refer to the following regarding preventing Sierra Chart from trying to download data for the symbol that you created the data for: Text/CSV Data Format: Using Your Own Data and Not Connecting to External Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-08 03:38:42
