Date/Time: Sun, 26 Jan 2025 07:05:55 +0000
Window minimizing itself
View Count: 700
[2019-01-06 03:11:52]
User169391 - Posts: 62
Hi
Why do some windows I have open minimize themselves after having viewed/changed chart settings or studies. This happens after I've done change's on either studies or chart settings then clicking apply/ok and then the window minimizes itself automatically. I gather this is a simple setting somewhere.
thanks
[2019-01-06 05:53:51]
No, there is no setting. It would have to be the operating system doing this. Sierra Chart would not do this on its own.
We see you are using Windows 10 so Windows 10 is to blame here. And no we make no apology about that. We put blame where the blame is.
[2019-02-13 18:20:49]
ARDAN - Posts: 66
I have the same problem. Which version of Windows should I use to avoid that annoying auto chart minimizing issue?
I use all my charts in a chartbook without title bars and scrollbar.
Date Time Of Last Edit: 2019-02-13 18:27:46
[2019-02-13 18:43:43]
You must enable the title bars. Otherwise, you can have unexpected behavior no matter what version of Windows that you use.
We will not provide further help with this.
Date Time Of Last Edit: 2019-02-13 18:43:58
