Date/Time: Fri, 24 Jan 2025 05:19:49 +0000
Problem in the TPO Chart
View Count: 872
[2019-01-05 01:31:44] |
novaxt123 - Posts: 43 |
Hello Please have a look at the attached picture. You will see the TPO Chart of the CLG9. Why are these gaps always at the End to the RTH (Cash) session at 2:30 pm? But only with CL is this problem. Is a setting wrong? Thanks. Best regards Jan Rabe |
[2019-01-07 00:07:52] |
User750920 - Posts: 280 |
Hi, I took a look at your picture. When I use the same settings my TPO profiles look different. For example on the 12-17 the low of the day is lower than what you show and the high of 12-18 is lower than what you show. I would look in the Settings for the Study itself. There is a setting within it called Use Custom Sub Periods - but the default (I tried it) doesn't produce the results you have. If you cannot figure it out this is what I would do. Duplicate a TPO chart that you say is correct so you do not mess up the original. Then change the symbol to CL and see what happens (making sure the session times is what you want) and see if that works. If not I would check into the TPO settings themselves - unless the symbol setup itself is off for some reason (seems unlikely) and I am not sure how to check that. |
[2019-01-07 14:24:43] |
Hi, Thats Ok now. Many Thanks for your Time. :-)
[2019-01-07 18:55:20] |
That was a user response. Not from us. In that chart, set the Session Start Time to 18:00:00 and the End Time to 16:59:59. This assumes the chart is using the New York time zone. Refer to: Chart Session Times Since that is a continuous futures contract chart, refer to: Continuous Futures Contract Charts: Displaying Rollover Transition Times and Contract Months Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-07 18:56:09
