Date/Time: Fri, 24 Jan 2025 03:46:32 +0000
[User Discussion] - Syncing orders between charts
View Count: 606
[2019-01-04 19:20:44]
User606491 - Posts: 164
What study (or other means) can I use to sync orders between charts?
For example, when using spread trades, I'd like to make sure:
1. a buy order on one chart is simultaneously executed with a sell order on another chart
2. the number of open contracts on one chart always equals a pre-determined ratio of contracts with another chart
thank you,
[2019-01-04 20:04:04]
I realize the "Trading: Spread Order Entry" is designed to do this. However, is there a way to use spreadsheets to control this study's inputs? For example 1) enter when the spread crosses a bollinger band (rather than setting a predetermined value in the study settings).
[2019-01-05 06:35:06]
You certainly could modify that study since the source code is provided and use the ACSIL spreadsheet functions to accomplish what you want.
Refer to:
sc.GetSheetCellAsDouble()
How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies
Date Time Of Last Edit: 2019-01-05 06:35:58
