Date/Time: Fri, 24 Jan 2025 05:12:42 +0000
SC slow
View Count: 957
[2019-01-04 18:45:26] |
arruga - Posts: 253 |
Hi I got a single chartbook, 6 intraday charts at different timeframes, two market profiles, and quoteboard with 10 symbols, linked to charts. I got drawings and studies on my charts. All my intraday charts use day/evening sessions, and customized session times. Streaming data from SC - all Services, and with or without connection to IB Trading Service, doesn't matter, equally slow. SC is too slow to load when I switch from one symbol to the other. It seems that every time I switch it downloads data all over again. Doesn't it store the data in cache or local memory or something? I think I heard something about it in Infinity Futures youtube. Is tere a setting somewhere to store in local memory instead of reloading everytime? It was them who recommended to use a single chartbook with a quoteboard instead of several chartbooks, for performance sake. Would you say that this is indeed the better option? But it takes too long swithching symbols. Please advise. thanks |
[2019-01-08 04:08:41] |
Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often It seems that every time I switch it downloads data all over again. No that is not the case.Refer to: Changing Chart Bars Period: Improving Performance of Loading Chart Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-08 04:26:39] |
It was them who recommended to use a single chartbook with a quoteboard instead of several chartbooks, for performance sake. In general this is not relevant one way or another. What does count is how many charts are visible at a time. The less the better.What will help most is a fast computer with NVME drives. And following the advice in help topic 30. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-08 04:27:25
