Date/Time: Fri, 24 Jan 2025 03:39:17 +0000
TICK VALUE SYNTAX
View Count: 962
[2019-01-04 17:18:48]
BLAKE R - Posts: 23
Good Morning,
Can you tell me what the syntax is for tick value? I recently found "TICKSIZE" and using it successfully. But I cannot find Tick Value in the literature.
Happy New Year,
[2019-01-04 19:08:49]
What you are referring to is the Currency Value per Tick and that is not available in alert formulas.
Date Time Of Last Edit: 2019-01-04 19:09:30
