Date/Time: Fri, 24 Jan 2025 03:31:27 +0000
Outline of Profile on TPO Charts no longer functions
View Count: 564
[2019-01-04 17:06:04] |
BenjaminR - Posts: 170 |
I've noticed in updating SC the last few times, the dashed outline that appears around an individual profile no longer appears. The first time this happened, it was back again after the next update. However, as in the prior update & the current release version 1856, it is not functioning again. Please do not discontinue this feature, or have a look to see if some conflict is overriding that funcionality. Thank you. |
[2019-01-04 18:43:26] |
What you are referring to is a selection outline and is only going to work when you have keyboard shortcuts set up for TPO profile charts: Time Price Opportunity (TPO) Profile Charts: Keyboard Shortcuts for Splitting and Merging Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
