Date/Time: Sat, 23 Nov 2024 05:49:45 +0000
Display volume bar for Bid/Ak size (DOM)
View Count: 3114
[2019-01-04 13:54:28]
MARTIN CREUSOT - Posts: 2
i want to configure my DOM , but i don't find the setting "Display volume bar for Bid/Ak size" on "Chart DOM setting Global" ?
is it possible ton set volume Bar width for Bid/Ask ?
[2019-01-04 19:06:54]
In order to turn on the Volume Bars within the DOM you need to go to Trade >> Customize Chart/Trade DOM Columns and then select the option for Volume Bars for those columns that you have displayed and want to see the volume bars.
The length of the volume bars is automatically determined by the maximum depth for that column or for the maximum Bid or Ask, depending on what columns you have displayed.
Refer to the following documentation:
Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns)
[2024-09-04 12:09:01]
Eranox - Posts: 26
Where is this setting? I don’t manage to find it..
The bars in the buy/sell coloum on the dom are too small. I dont know how to make them widther
Date Time Of Last Edit: 2024-09-04 18:32:31
[2024-09-04 21:32:17]
Refer to the following settings:
Global Trade Settings Windows: Recent/Current Volume Bars Length Relative to Bid and Ask (Global Settings >> Chart DOM Settings >> Other >> Other Settings)
Global Trade Settings Windows: Maximum Volume Bar Width Percentage (Global Settings >> Chart DOM Settings >> Other >> Other Settings)
Date Time Of Last Edit: 2024-09-04 21:32:46
[2024-09-05 10:45:21]
Eranox - Posts: 26
I tried but the market depth bars continues to be too small..
Date Time Of Last Edit: 2024-09-05 10:49:21
imageScreenshot 2024-09-05 124222.png / V - Attached On 2024-09-05 10:45:55 UTC - Size: 20.36 KB - 47 views
imageScreenshot 2024-09-05 124222-2.png / V - Attached On 2024-09-05 10:49:18 UTC - Size: 26.38 KB - 40 views
[2024-09-05 14:42:30]
That would be because there is a large value somewhere outside the visible range that is causing the other bars to be small. You can limit the number of levels that are displayed via the following setting:
Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu)
