Date/Time: Fri, 24 Jan 2025 03:30:09 +0000
Gain/Forex.com connection
View Count: 1058
[2019-01-04 13:18:48] |
User247273 - Posts: 37 |
Are there any plans to add a Forex.com connection for spot Forex trading? If not, is there a technical reason, or would you be open to possibly adding one in the future? I currently have to use 2 platforms for trading and I'd love to be able to just use Sierra because it's the perfect platform for my needs and my approach to trading. |
[2019-01-04 18:39:07] |
No this will definitely not come. Refer to: Notice: Suggestions (Currently not accepting) If those guys are not going to work with us and adopt the DTC Protocol, then we will have nothing to do with them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-05 08:17:14
