Date/Time: Fri, 24 Jan 2025 03:31:15 +0000
Isn't it possible to see depth data for charts smaller than 5 sec?
View Count: 677
[2019-01-04 09:47:47]
User452567 - Posts: 38
If I try to reduce my chart with bid and ask depth bars I'm receiving the error of: Failed to add to the depth data for CLG9-NYMEX, possibly as a result of running out of memory. The depth data accounted for 106 megabytes of memory. Depth data will be unavailable until the chart can be reloaded. | 2019-01-04 03:45:18 *
Message Log:
Software version: 1853 32-bit | 2019-01-04 03:45:05
Enabled for: Advanced Features. | 2019-01-04 03:45:05
Enabled for: Advanced Features 2. | 2019-01-04 03:45:05
Enabled for: Sierra Chart Historical Data Service. | 2019-01-04 03:45:05
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-01-04 03:45:05
Current selected Data/Trading service: Rithmic Trading | 2019-01-04 03:45:05
Chart Update Interval: 500 | 2019-01-04 03:45:05
Data/Trade Service Settings automatically set. | 2019-01-04 03:45:05
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-01-04 03:45:05
2019-01-04 03:45:04 Local computer time | 2019-01-04 03:45:05
2019-01-04 09:45:04 Local computer time in UTC | 2019-01-04 03:45:05
2019-01-04 03:45:04 Local computer time in SC Time Zone | 2019-01-04 03:45:05
2019-01-02 20:45:16 Server time in UTC | 2019-01-04 03:45:05
Local computer UTC time and Server UTC time difference: 2 seconds. | 2019-01-04 03:45:05
Program path: C:\SierraChart\ | 2019-01-04 03:45:05
Data Files path: C:\SierraChart\Data\ | 2019-01-04 03:45:05
OS Version Number: 10.0 | 2019-01-04 03:45:05
Locale Setting: C | 2019-01-04 03:45:05
DLLs: BDOTSv6 (1).dll, BDOTSv6.dll, ETOFSv2.0.dll, ETOFSv2.0_64.dll, MB-FTT (2).dll, MB-FTT.dll, MK_CumulativeDelta30min (1).dll, scanABVDT_b2.dll, scanABVDT_b3.dll, speed_of_tape.dll, sst_FreeBundle.dll, sst_FreeBundle_64.dll, sst_pulling_stacking.dll, sst_pulling_stacking_64.dll, Statistics.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-01-04 03:45:05
CLG9-NYMEX 10 Sec #1 | Reloading chart. | 2019-01-04 03:45:06
+ Loading market depth data. | 2019-01-04 03:45:06
Loaded depth data records for CLG9-NYMEX 2019-01-04 from 2019-01-03 18:00:00 to 2019-01-04 03:45:05. | 2019-01-04 03:45:07
CLG9-NYMEX 5 Sec #1 | Reloading chart. | 2019-01-04 03:45:15
+ Loading market depth data. | 2019-01-04 03:45:15
Loaded depth data records for CLG9-NYMEX 2019-01-04 from 2019-01-03 18:00:00 to 2019-01-04 03:45:05. | 2019-01-04 03:45:15
CLG9-NYMEX 4 Sec #1 | Reloading chart. | 2019-01-04 03:45:18
+ Loading market depth data. | 2019-01-04 03:45:18
[2019-01-04 16:43:18]
John - SC Support - Posts: 37448
Try using the 64-bit version of Sierra Chart:
Software Download: Difference Between 32 and 64-bit Versions
