Date/Time: Fri, 24 Jan 2025 05:19:20 +0000
[Programming Help] - Help on attach trade chart !!!?
View Count: 1074
[2019-01-04 08:24:39]
1234567 - Posts: 42
Attach window trader to chart is not triggering the right time, help please
1)i know my code in spreadsheet is right because i can see the bright green arrow is Lined up under green bar, the in chart screen. but not attach window trade to chart is not Lined up at all with my code,
2) i have made assure sim3 is lined with spreadsheet and auto trade system bar based backtest.
ever time my Attach window trader to chart is not triggering not lined up with any of my code or my studies,
btw i have done this with different chartbook, and they to have not lined you at all
here is the codes
O3:
=IF(OR(E3>B3,AND(B3>E4,B3=E3)),-1, IF(OR(E3<B3,AND(B3<E4,B3=E3)),0,O4))
K3
=AND(O4=0,O3=-1)
L3
=AND(O4=-1,O3=0)
Thank you
Private File
Private File
Private File
[2019-01-04 16:18:43]
1234567 - Posts: 42
help how to i fix this?
[2019-01-04 18:32:45]
Refer to:
Automated Trading Management: Troubleshooting Automated Trading System Behavior
[2019-01-04 22:01:13]
1234567 - Posts: 42
ok but how do i reset my Attach Trade Window to chart, because is not triggering in the chart, and yes the "sim" is right.
Attach Trade Window to chart is not triggering, but my spreadsheet is triggering.
[2019-01-05 19:40:26]
Not sure we understand the question but you need to go to the chart and then select Trade >> Attach Trade Window to Chart from the menu. Does that answer your question?
[2019-01-05 23:30:11]
1234567 - Posts: 42
yes i already did that Trade >> Attach Trade Window to Chart and made it was checked, i also made sure the sim6 was is matching is the spreadsheet. but here the problem, Attach Trade Window to Chart is not triggering is the wrong place, but the spreadsheet is triggering is the right place, i like to know how to fix Attach Trade Window to Chart. not the spreadsheet. how do i fix this?
thank you
[2019-01-08 09:28:53]
We are really not understanding this. But one thing that we see is that this is a Historical Daily chart. We recommend that you change to an Intraday chart instead. Refer to:
Chart Session Times: Creating Daily Bars with Custom Session Times
Date Time Of Last Edit: 2019-01-08 09:29:12
