Date/Time: Fri, 24 Jan 2025 03:46:14 +0000
displaying data from formula
View Count: 595
[2019-01-04 06:25:14]
stocknerd1 - Posts: 10
Hello, I am wondering if I can display values from finding the difference between two studies.
For example display the difference between 2 moving averages on the same chart.
With the same example could I write the formula and display multiple difference values?
Thank you in advance for your time.
[2019-01-04 15:04:26]
Sawtooth - Posts: 4162
Use an instance of the Study Subgraphs Subtract/Difference study for each display.
[2019-01-04 18:06:57]
Refer to this page:
Using the Basic Arithmetic Studies: Introduction
