Date/Time: Fri, 24 Jan 2025 03:46:14 +0000
alerts won't stop
View Count: 1027
[2019-01-03 16:01:33] |
User807026 - Posts: 86 |
I was using studies on 2 separate charts, Keltner Channel and Color Background based on Alert Condition with sound alerts. I wanted to stop the sound alerts. First I disabled the alert, then I picked No Alert Sound, then I removed the code in the alert box and finally I removed the studies from the charts. The alerts are still sounding and showing on the Alert log. I don't want to disable all alert sounds because some I find very useful. How do I stop these alerts that are no longer on the charts from sounding?
[2019-01-04 02:06:29] |
Refer to: Alerts Manager: Disabling Alert Sounds Refer to the following to clear the Alert Sound Queue: General Settings Window: Clearing the Alert Sound Queue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-04 02:06:52
