Date/Time: Fri, 24 Jan 2025 03:45:00 +0000
Orders and positions are not showing open positions
View Count: 1046
[2019-01-03 11:36:52] |
grantx - Posts: 244 |
I have a trade with a stop and a target. On the 'orders' tab I can see the limit order and stop order. On the 'positions(non-simulated)' I cannot see my order. Where do I go to see it and close it?? |
[2019-01-03 14:13:01] |
You will need to adjust the Order Fills Start Date-Time in the Chart >>Chart Settings to get the correct position quantity displayed. Refer to: LMAX Trading Service: How Current Trade Positions Are Determined Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-03 14:13:57
