Date/Time: Sun, 24 Nov 2024 12:36:18 +0000
IB data feed
View Count: 1358
[2013-11-08 22:33:37] |
User93731 - Posts: 81 |
Hi: After I download the newest version of SC, My data feed from Intractive brokers is NOT longer working. It seems to ask me to dowload the higher version of IB. I used the web-based connection , not from the stand alone version. I hit the button from SC to upgrade the IB, however, it told me that my pc can not find the pervios version. I would still like to use the web-based of IB for my data feed. what shoudl I do? I also tried to reload the older version of SC, the overwriting fail as well. What shoudl I do now? Thanks Hiwhited |
[2013-11-09 03:15:06] |
Please install the standalone full TWS version and then update it to the latest release. And use that. You can get it from the Interactive Brokers website.
