Date/Time: Fri, 24 Jan 2025 03:43:57 +0000
Future
View Count: 763
[2019-01-02 18:30:08] |
GIOVANNI ZANANTONI - Posts: 2 |
Buona sera io ho i grafici dei Future fermi ,non riesco a capire il motivo....grazie
[2019-01-03 18:10:14] |
Buona sera, Not sure we understand the question. So you are asking about futures charts? What particular symbol and can you be more specific about your question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-04 20:07:59] |
User136422 - Posts: 33 |
He's saying that his futures charts are all frozen, and he don't understand why it's happening.
[2019-01-04 20:25:48] |
Okay understood. Here is the relevant documentation for that: Is Historical and Real-time Futures Data Included? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
