Date/Time: Fri, 24 Jan 2025 06:40:16 +0000
number bar calculated
View Count: 744
[2019-01-02 13:46:48] |
User184582 - Posts: 14 |
Hello , I use number bar calculated as new indicator. When i go into the settings for selected "color background based on value percentage yes" the colors don't change i see only two colors all the time. Can you lead me to resolve this issue please? Thanks Date Time Of Last Edit: 2019-01-02 13:49:56
[2019-01-02 21:39:30] |
John - SC Support - Posts: 37448 |
There is one of two issues going on with what you describe. The first is simply that the data only falls into two ranges. I have seen this myself where there is maybe 1 outlier which then pushes the rest of the data into a smaller range. Refer to the following documentation for how the colors are determined and then see if the numbers are in the correct bands: Numbers Bars: Calculated Values Background Coloring Logic The second is simply that the colors you have for the ranges are the same, or very close and therefore you are not able to tell them apart. Refer to the Range # Up Color and Range # Down Color Inputs in this section: Numbers Bars: Numbers Bars Calculated Values Input Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-14 13:29:58] |
Hello John. i noticed sometimes SC deconnected for few second and reconnect automaticly , sometimes several times in the day. does other customers met this issue ? thanks |
[2019-01-14 14:38:03] |
In general most customers do not have this issue, and most of the times that people do it is typically related to the Internet connection that they have available, or to the particular data provider. What service are you using for your data? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-14 14:42:55] |
I use GAIN OEC data feed
[2019-01-14 18:16:40] |
Refer to the following documentation to see if any of these might apply to your situation: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ConnectionProblem For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
