Date/Time: Fri, 24 Jan 2025 03:35:24 +0000
View Count: 707
[2019-01-02 19:36:36] |
You are using the colors incorrectly. Refer to the following: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DataColor[] Also, if you are applying this to the Bid Volume vs Ask Volume study, then you should not be using DRAWSTYLE_COLOR_BAR, but should be using the same drawstyle as the Subgraphs of the study use. In this case, it would be DRAWSTYLE_BAR. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
