Date/Time: Fri, 24 Jan 2025 03:36:22 +0000
Connection Error
View Count: 617
[2019-01-01 15:28:55] |
User725607 - Posts: 1 |
Hello, i can not connect to the Sierrachart/ Datafeed. Error Message: UserName does not exist. |
[2019-01-01 15:29:07] |
Sierra Chart - Max - Posts: 5779 |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support |
[2019-01-01 20:44:36] |
What you actually are referring to is connecting to CQG. Refer to: CQG Trading Platform Service: Common Error Messages Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
