Date/Time: Fri, 24 Jan 2025 03:30:24 +0000
insatnces and number of computers i can use the platform on
View Count: 596
[2018-12-31 19:58:41] |
User317484 - Posts: 15 |
Two Questions: Can i install sierra charts platform on several computers that i use at work and at home (say 3 additional to the primary one i have now). I would only plan to be logged into one platform at any one time ? How many instances can i create ? do you have a number of instances that you recommend limiting to ? |
[2018-12-31 21:00:03] |
Yes all of this is supported. You can create as many instances as you need. Refer to: Sierra Chart Purchase and License Information: Licensing / Number of Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
