Date/Time: Sun, 24 Nov 2024 12:51:08 +0000
Zig Zag not working properly since update
View Count: 1394
[2013-11-08 18:20:10]
User52989 - Posts: 42
Hi - downloaded v1042 and the zig zag indicator all of the sudden doesn't work properly. I don't use the lines, but just where it shows the highs and lows for harmonic rotations - in other words, at each rotation it shows the price and the end of the leg and how many ticks. Since the update, when I load SC, it only shows a small handful of rotations. Each time I fire it up, I have to go into STUDIES and click "hide" for zig zag study, click APPLY and then uncheck HIDE and re-click APPLY and it works fine. I have to do this manually for each chart. I noticed on the update log you in fact changed something in that study a week ago - whatever you changed it causing this annoying bug. I've used ZZ study for a LONG time and never had this issue until this last update. Thanks in advance.
[2013-11-08 18:33:38]
BTW, I uninstalled the zig zag and re-installed it; no change.
[2013-11-09 03:11:21]
Could you provide us a Chartbook containing a single Chart with the Zig Zag study as you have it configured so we can test this. Here are the instructions:
https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile
