Date/Time: Fri, 24 Jan 2025 05:33:34 +0000
Hiding the pointer in the crosshair
View Count: 1012
[2018-12-31 10:59:21]
User257019 - Posts: 25
Dear team,
As the crosshair basic feature is to show you where your pointer is, I would like to know if it´s possible to remove the Windows pointer of the mouse when you are inside a chart. This way you would only see the crosshair.
Thanks!
[2019-01-06 21:32:29]
Hello team,
I´ve read already this article:
Chart Drawing Tools: Controlling the Type of Pointer Displayed When Using Drawing Tools
Just wanted to know if you would allow (in the future), the possibility of removing any pointer, so the crosshair acts as pointer itself.
I´m attaching the trade window to the chart so I see the normal select pointer.
Thanks!
