Date/Time: Fri, 24 Jan 2025 03:35:17 +0000
Is it able to distinguish each price of peaks and valleys for VbP?
View Count: 799
[2018-12-30 18:26:46]
ikeakn - Posts: 1
Hello, I have a question for peaks and valleys in VbP.
For example, there may be many peaks and valleys if peak and valley sensitivity is low.
Then can I see the price of each peak and valley through Chart Values Window?
I checked both 'Display Name and Value in ChartValues Windows' of volume peaks and valleys to yes in subgraphs section and learned that I can see each price of them on the chart, but not in CVW.
Date Time Of Last Edit: 2018-12-30 18:31:06
[2018-12-31 18:52:03]
You need to enable Value Labels for these lines. That is the only way. So they can only be seen on the chart. Refer to:
Volume By Price Study: Volume Peaks (SG18)
And refer to:
Chart Studies: Subgraphs Tab >> Name and Value Labels
Date Time Of Last Edit: 2018-12-31 18:53:09
