Date/Time: Fri, 24 Jan 2025 03:37:26 +0000
downloading
View Count: 637
[2018-12-29 22:50:33] |
Ed Meckelborg - Posts: 71 |
I got a new laptop. I cannot download one SC for the interactive Brokers acct and another for Just Historical charts I have windows 10. please help. I can download for one of them, but the second one is the same as the first one |
[2018-12-31 21:23:15] |
It sounds like you are trying to install 2 separate instances of Sierra Chart. When you do this, you need to change the installation folder of the second instance, or else you will just be overwriting the first installation you did. Refer to the following instructions: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
